TheNewbie Posted February 20, 2012 Report Posted February 20, 2012 So I understand what cone area is.. just a little confused as to what it does. EX: Level 4 12 and a level 4 15, one will push more air, (the 15) while the 12.. does? With the 15 I should feel it more but what should happen with the 12.. if that makes any sense.. trying to basicly figure out. The difference, other than ones bigger and has more cone area. Thanks. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
TheNewbie Posted February 20, 2012 Author Report Posted February 20, 2012 That i understand.. i guess what im trying to ask is the difference in the feeling? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
JWBryant Posted February 20, 2012 Report Posted February 20, 2012 Sound pressure level is sound pressure level, it should feel the same just louder Basshead-in-Training
KillaCam Posted February 20, 2012 Report Posted February 20, 2012 Just because its bigger doesn't necessarily mean it will be louder. More air moving, blurred vision, twitchy nose are some things you can feel. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
HHR Ed Posted February 20, 2012 Report Posted February 20, 2012 Cone area is only one factor. Box design is a much larger factor in loudness and "FEEL". If you have a perfect box for both woofers, and the same power. You will most likely not hear or feel any difference. Just because it is a 15, does not mean that it will feel any different than a 12. A 12 doing 145 dB at 40hz will have the same feeling as a 15 doing 145 dB at 40hz. And both are perfectly capable of doing that SPL. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
BigPimpin91 Posted February 20, 2012 Report Posted February 20, 2012 Cone area is only one factor. Box design is a much larger factor in loudness and "FEEL". If you have a perfect box for both woofers, and the same power. You will most likely not hear or feel any difference. Just because it is a 15, does not mean that it will feel any different than a 12. A 12 doing 145 dB at 40hz will have the same feeling as a 15 doing 145 dB at 40hz. And both are perfectly capable of doing that SPL. Not unless your name is BigPimpin'. LoL BigPimpin91's Banging Music
