Ray Posted February 21, 2012 Report Posted February 21, 2012 I had a mayhem in that size 4th. Did great. Maybe 2-12's in a 6th?? 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
audiofanaticz Posted February 21, 2012 Report Posted February 21, 2012 SP4 is designed for bandpass iirc No, its not... Just because the QTS number fits a charismatic, it does not mean it is designed for bandpass boxes only. If that was the case it would say "ONLY USE THIS WOOFER IN BANDPASS ENCLOSURES" But it does not say that on Fis website nor other threads. Went thru this already with AMI and JD1102. A company that designs a woofer strictly for 1 box application is not going to be a very big seller. Perfect example, Digital Designs with the Z woofer which is strictly SPL oriented, while its the loudest single sub setup in the world, its not a top seller, nor do people only use them for spl. Seen a few people attempt to use them in musical applications. There are many people using woofers with the wrong qts in 4th orders. Look at Sanitarium using AQ HD3's in a 4th and 6th orders... Also Ray using a AA Mayhem in a 4th order... Both users have great results using a woofer without the qts being in 4th order only range like people keep assuming...
CortezDTV Posted February 21, 2012 Author Report Posted February 21, 2012 I had a mayhem in that size 4th. Did great. Maybe 2-12's in a 6th?? how would i go about tunin a 6th order and what about the size of the chambers? for 2 n2 12s because i allready have 1 motor and basically same softparts as the mayhem anyway isnt it? SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
Ray Posted February 21, 2012 Report Posted February 21, 2012 4-4.5 rear chamber 14sqin per Tune to 35ish Front chamber 3.5 ish with 20per Tuned up around 65-70ish. Thats where i would start. Really need to plot it and see where the f3 points are. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
CortezDTV Posted February 21, 2012 Author Report Posted February 21, 2012 looking at 6th order is i made the top 3.97 gross tunned to 63 8x10 8in long port firing forward or up threw back deck which even sounds better and for the bottom i did 35 hz 4.38 cubes and 8x6 inch port 25 inches long??? ray does that box seem good for 2 n2 12s? what do you mean mappin the f3 points, when the frequency rate dropps off, and change tunin according to that after? where would you put the port, in the middle and in the middle? and thanks for all the help too SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
CortezDTV Posted February 22, 2012 Author Report Posted February 22, 2012 ray more input please haha SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
CortezDTV Posted February 23, 2012 Author Report Posted February 23, 2012 bump SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
Ray Posted February 23, 2012 Report Posted February 23, 2012 Ahhh found it. Lol. Lost ya for a sec. So..... 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted February 23, 2012 Report Posted February 23, 2012 Bump it tomorrow so i can find it and plot something for ya 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
CortezDTV Posted February 23, 2012 Author Report Posted February 23, 2012 Will do thanks a ton man! SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
