I've had an annoying high pitch, low volume tone coming from my speakers and narrowed it down to one of the SAZ3000's I have strapped. RCA's disconnected from the amp and the sound is gone.
I also diacovered that if I tap on the case of the amp that's causing the noise it'll make a crackling sound from the speakers with each tap.
Everything was fine until I put in the 2nd amp. Bought it used so I don't know the total history. Anybody have an idea of what inside the amp could be causing this issues?
High pitch noise and a tap induced crackle sounds like a broken/cracked solder joint in the signal path. Pull the cover and look for a bad solder joint at the rca's and through the remaining signal path. Make sure all your grounds are solid.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Finally got a chance to yank it out. Pulled the cover and didn't see any broken joints. Put it back together and hooked it back up to try pinpoint it better. Figured out that if I wiggle the RCAs it'll make the crackling sound. Also found out that if Im holding the RCA and touching the plate they're mounted to I actually got a small shock. I'm guessing that the tone
I'm hearing is AC voltage that's being induced into the RCAs from that one amp. Just need to yank it out again and try pinpoint where it's bad.
Any ideas?
my AB 1100.1 made a sound when I would hit bumps in the road.....
the solder joint where they were connected to the board was broke... ARC in ohio found it and fixed it for me ... i couldnt see it was broke
The RCAs on the saz are connected to the board via a set of cables with plugs that go into the board. So with that I'm kinda thinking it's one of the RCA plugs that's tightened on the end cap that's got a bad joint somewhere. Might just swap those pieces from one amp to the other to confirm that's what it is. Easier than taking all the time to re solder only to find out its something else.
Never saw a cold solder in person, but i had a vew! You couldn´t see cold solder normaly :lol2:
"in the abundance of water, the fool is thirsty" Bob Marley
So here's what I figured out:
All solder joints around RCAs are good, swapped end cap with RCA's to confirm.
With the RCA piece screwed in place on the amp, it goes into protect. If I remove that piece and just leave the two plugs from the RCA's connected to the board it starts up fine.
The high pitch tone is there when the amp isn't in protect (end piece not screwed in place) but if I ground the outside of one of the RCAs the high pitch tone disappears.
Any idea what's going in here? I know it ain't the RCA's on the amp but I'm thinking it's some type of ground problem in the amp. Help...
I swapped the end piece that holds the RCAs and their soldered connections with the other amp I had and it was fine.
Took it out and checked everything again. Noticed that the power AND protect light are both on. Also, with the end piece in place if I touch the outer metal of the RCA and the case I get shocked. Nothing major but enough to feel it and know its there.
sounds more like your amp has a long lead somewhere that is touching the casing
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
