I messed around with a front port like tht decaf but i couldnt get the tuning low at all, it was up in the 80s. and idk about the mimi pics ill play around and try make them bigger when i have time.
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
that's a sign that your box needs to be bigger ;)
have you tried aeroports?
the box is already bigger then recomended, and they do like smaller boxes. heres the tores for it. Also i dont have anywhere to get aero's and last time i tried to flare pvc just to see if it was a option it didnt work to well. so a slot is my only option really tored.jpg
edit: uploaded the tores screenshot that didnt have displacement
Edited by RCP Audio
PSN: Rcp_soundz
ok i rounded a couple of numbers here and i'm not sure exactly what subs you're using but you get the point.
use the front and back of the box as part of the port (hence 2 common port walls)
you can round the length of the port if you want.
when the port reaches the bottom of the box and needs to split, use half the width of the port. like this:
here's the specs (rounded) of your box
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
tores.jpg what about this one? i just made it a little deeper (now at max max dimensions) does it look a little better?
PSN: Rcp_soundz
What 12" subs are you going to use? Your original port can work.
I beleive they are in my sig.
and im quickly converting cvx's box to MM so i can start making it hahaha, idk how its possible to get it to work so well so quickly, it took me ages to get to where i was (first box design tho)
PSN: Rcp_soundz
i've used the program a few hundred times lol
yeah thatl be why then hah. thanks for your help man, im now trying to turn it all into mm then i can start cutting (it sucks having a full sheet of wood staring at you and your still drawing up shit lol)
PSN: Rcp_soundz
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
