4 type r 12s
So i'm thinking of a new build for my explorer. I want 4 type r 12s in a box tuned around 33 to 35ish, but i want to know if i can run them on 6k daily with the proper wiring. Also maybe could run them off a lanzar 6k if possible, or any other amps thats good for that amount of watts. I have another question, i hate rattling i know alot do but if the port is further away from the back latch can that take out alot of rattling?
yea they should be able to take that 6k daily I know each one can be ran at around 1k-1.2k and with that amount of power and subs its gonna be hard to reduce rattle man haha
Impossible for someone to design you something without having dimensions
well since i just got the truck yesterday i havent took mesurements yet, but aiming for something that's not to high and is not so close to the back latch.
Ok get them when you can and consider that the box have also to fit on it's way in. Many times I have seen this problem
I would look around for a different amp instead of that Lanzar also. But 4 of those subs should get pretty loud.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
NO NO NO. you can not run Alpine type R at 1-1.2k daily. and how does that add up with 4 of them to 6 k. they would each be getting 1500rms if the lanzar amp actually did 6krms. i wouldnt put over 800 ot a type r daily. a burp is different. daily those type rs will burn up and youll wonder why. do not put more than 800rms daily. maybe you can get away with just under 1 k but no more than 1k a piece. 2nd, get a good amp. Lanzar? if you want results of that video you posted OP, your gunna have to use a sub on the same level as an Fi woofer and an amp that can push clean rated power. I have personally run alpines in the past on a budget buidl. so if your trying to go cheap hit me up. just please dont put a type r on over 1k dailyy
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 985 Guests (See full list)
