egag Posted February 23, 2012 Report Posted February 23, 2012 i just ordered an Fi Q 18 and i dont know how i should make the box (sub up port back. ETC...) i drive a 94 jeep cherokee 4 door any suggestions? 1994 Jeep Cherokee !@#$%^&*(Soon to come)*&^%$#@! TONS AND TONS of Audio Technix 80Mil 1 x 270 Amp Mechman Alt 1 x AQ3500D.1 1 x Rockford Fosgate T600-4 8 x Rockford Fosgate T2652-S 2 x XS Power D3100 1 x XS Power D3400 1 x eKs Kable 2 Channel Silver Plated RCA 5M 1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT. 1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT. 4 x Avenue - A605 2 x Fi Q 18
Joe X Posted February 23, 2012 Report Posted February 23, 2012 Subs up port back is what usually is done for that type of vehicle, what are your maximum dims and I will give you a design suggestion.
egag Posted February 23, 2012 Author Report Posted February 23, 2012 24 height 40 depth 24 width (can go a little bigger if needed) 1994 Jeep Cherokee !@#$%^&*(Soon to come)*&^%$#@! TONS AND TONS of Audio Technix 80Mil 1 x 270 Amp Mechman Alt 1 x AQ3500D.1 1 x Rockford Fosgate T600-4 8 x Rockford Fosgate T2652-S 2 x XS Power D3100 1 x XS Power D3400 1 x eKs Kable 2 Channel Silver Plated RCA 5M 1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT. 1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT. 4 x Avenue - A605 2 x Fi Q 18
stevog Posted February 23, 2012 Report Posted February 23, 2012 for suvs i heard that sub up port back is best
Joe X Posted February 23, 2012 Report Posted February 23, 2012 So here is a suggestion: Enclosure Specifications: Fb = 30.5 Hz Vb = 8.5 ft^3 Subwoofer Mounting = Flush Mounted External Height = 24 in External Width = 24 in External Depth = 40 in Port Width = 5 1/2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 24 x 40 Left & Right Sides = 38 1/2 x 21 3/4 Front & Back = 24 x 21 3/4 L Port Internal Assembly Parts: Front to Back = 29 1/4 x 22 1/2 Sub on top. Port inner wall goes all across the bottom of the back wall (good if nothing blocks airflow at that position). Cross bracing applies across the width and top to bottom. Let me know any questions.
