vans113 Posted February 23, 2012 Report Posted February 23, 2012 Alright guys heres my setup my head unit is a kenwood kdc-138 I have two 10 inch kicker compvr's bridged at 4 ohms on a 1000 watt sony explode amp, and here's my issue. I'm not sure weather this could be a ground loop issue or something to do with my rca's but I have a constant humming from my subs and it never stops... EVER sometime If I shut my glove box etc I can hear it though my subs. I'm running 6 gauge power, and ground also, and yes they are on separate sides of the car. I have tried electrical taping up my power and ground, and my rca wires at the amp, and that did don't help one bit. I can post pictures of anything If anybody needs to see anything, and any help is appreciated. Thanks for reading =D
varietyguy Posted February 23, 2012 Report Posted February 23, 2012 It's a ground loop. Where is your amp grounded. Just to clarify, you have your rca's ran on the opposite side as the power wire? What vehicle is it in? Redo amp ground, scrape paint away for solid ground. check rca's might have to get better ones. Get bigger wire. check ground on head unit, redo. 1992 Mazda 323 http://www.stevemead...323-wall-build/
vans113 Posted February 23, 2012 Author Report Posted February 23, 2012 Yes it is ran on the opposite side from the power wire, and its in a 2004 chevy caviler, I have it grounded to the top of the strut tower currently with all the paint scraped away, and I have unplugged the rcas out of the amp and there is no noise, wouldn't that cancel it out being a ground loop issue?
BFF Larry Posted February 23, 2012 Report Posted February 23, 2012 Could also be just the amp itself. Try swapping amps with a friend and see if the noise stops Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Kdub26 Posted February 23, 2012 Report Posted February 23, 2012 What brand RCA's are you running? 1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp? That thing is going to eat people nearby cars, unsecured objects, and small childrenFixed!wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho hahaGet a new girlfriend.
vans113 Posted February 23, 2012 Author Report Posted February 23, 2012 I could try the amp thing, and schoce or however you spell it from walmart? and the head unit is grounded all though the stock wiring just with the after market adapter
vans113 Posted February 25, 2012 Author Report Posted February 25, 2012 Thanks for all the help above guys when I get a day off from work, and have some free time. I'm gonna pull out the headunit and see about the ground on it maybe add another ground fr it. I'll keep you guys posted again thanks for all the help!
XRipSticKX Posted February 29, 2012 Report Posted February 29, 2012 get better rca i had the same problem with those same cables on an older system and make sure they are away from the power cable NISSAN SKYLINE GTR R32 (Build in progress)Fosgate POWERhttp://www.stevemead...-fosgate-power/--------------------------------------------------------------------97 Honda AccordRockford Fosgate1400 watts RMS totalhttp://www.stevemead...e-1400watt-rms/---------------------------------------------------------------------
