Subject 12'' Punch Hx2 should I port them or keep them in my sealed box. My problem has always been trunk space, I own a Honda and well you already know. My current system sounds decent, the box is chambered 1 cubic ft. per sub But I know there can be more shake. Oh and Ps if I do decide to port = im on a tight budget what so you think about 4'' PVC for the mean time. im thinking port noise
Edited by Bigvell
Max dims. W = 30.25 H = 13 D = 28 I know not much space :search:
Yes you can do ported very well on that space with 3 4" aero ports (flared), ports/subs in the same face front firing is suggested, take a look:
Enclosure Specifications:
Fb = 36.048 Hz
Vb = 4.128 ft^3
External Height = 13 in
External Width = 30.25 in
External Depth = 28 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 30 1/4 x 13
Left & Right Sides = 25 3/4 x 11 1/2
Top & Bottom = 30 1/4 x 25 3/4
Port Quantity and Dimensions:
Number of Ports = 3
Pipe Port Diameter = 4
Pipe Port Length = 16
Top to bottom and front to back crossbracing applies. Let me know any questions.
Edited by Joe X
Fb = 36.048 Hz
Vb = 4.128 ft^3
Cut List:
Number of Ports = 3
4 cubes seems a bit large for a 12 don't you think?
Fb = 36.048 Hz
Vb = 4.128 ft^3
Cut List:
Number of Ports = 3
It says "port them"
I like, I like. I have 2 hx2s, My bad about those dims. I have a bunch of ideas wrote down on flash cards & i gave the wrong one lbs. dims = W30.25 H13 D26 I figured 3.94 cubic ft minus the space from the subs. What do you think
Edited by Bigvell
It will sound tight but still on spec:
Fb = 36.06 Hz
Vb = 3.687 ft^3
Subwoofer Mounting = Flush Mounted
External Depth = 26 in
Cut List:
Left & Right Sides = 23 3/4 x 11 1/2
Top & Bottom = 30 1/4 x 23 3/4
Number of Ports = 3
Pipe Port Length = 18 1/4
As before top to bottom and front to back crossbracing applies.
Edited by Joe X
Joe, I think you might be looking at the specs on the 18 or something.
3.7 cubic feet is ENORMOUS for a single 12 inch sub.
It's two subs Snowdrifter!!
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
