Box decisions
Subject 12'' Punch Hx2 should I port them or keep them in my sealed box. My problem has always been trunk space, I own a Honda and well you already know. My current system sounds decent, the box is chambered 1 cubic ft. per sub But I know there can be more shake. Oh and Ps if I do decide to port = im on a tight budget what so you think about 4'' PVC for the mean time. im thinking port noise
Edited by Bigvell
Yes you can do ported very well on that space with 3 4" aero ports (flared), ports/subs in the same face front firing is suggested, take a look:
Enclosure Specifications:
Fb = 36.048 Hz
Vb = 4.128 ft^3
External Height = 13 in
External Width = 30.25 in
External Depth = 28 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 30 1/4 x 13
Left & Right Sides = 25 3/4 x 11 1/2
Top & Bottom = 30 1/4 x 25 3/4
Port Quantity and Dimensions:
Number of Ports = 3
Pipe Port Diameter = 4
Pipe Port Length = 16
Top to bottom and front to back crossbracing applies. Let me know any questions.
Edited by Joe X
Fb = 36.048 Hz
Vb = 4.128 ft^3
Cut List:
Number of Ports = 3
4 cubes seems a bit large for a 12 don't you think?
Fb = 36.048 Hz
Vb = 4.128 ft^3
Cut List:
Number of Ports = 3
It says "port them"
I like, I like. I have 2 hx2s, My bad about those dims. I have a bunch of ideas wrote down on flash cards & i gave the wrong one lbs. dims = W30.25 H13 D26 I figured 3.94 cubic ft minus the space from the subs. What do you think
Edited by Bigvell
It will sound tight but still on spec:
Fb = 36.06 Hz
Vb = 3.687 ft^3
Subwoofer Mounting = Flush Mounted
External Depth = 26 in
Cut List:
Left & Right Sides = 23 3/4 x 11 1/2
Top & Bottom = 30 1/4 x 23 3/4
Number of Ports = 3
Pipe Port Length = 18 1/4
As before top to bottom and front to back crossbracing applies.
Edited by Joe X
Joe, I think you might be looking at the specs on the 18 or something.
3.7 cubic feet is ENORMOUS for a single 12 inch sub.
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
