http://www.kicker.co..._building_hints
If you are going to bend the port at 90° you will need to add 1/2 of the ports height to the length! See Below.
enclosures_22.jpgExample:
(Fig. 1)
Hport = 3"
Wport= 10"
Lport = 20"
(Fig. 2)
Since Hport is 3" you need to add
1.5"( 1/2 Of Hport) tO Lport. This
means that L1 + L2 = 21.5"
Always measure L1 and L2 down
the center to get an accurate
measurement!
Here are a couple more examples of the different shape enclosures you can build. The woofer can be mounted on the same side as the port or the back side of the enclosure can be slanted to fit up against your back seat.. On the cut sheets we provide, change the dimensions to accommodate the woofer and the vent on the same side. Make sure the internal volume does not change!
Edited by carshateme
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
It's from their website......as posted previously...
  • 3 weeks later...
Better read this one:
http://www.jlaudio.c...re+Ports/656168
The Torres is based on this document, the and correction applies only once.
really interesting, thanks for the info, still not sure about bending round ports though...
Using a round port you wont have a common wall of port and enclosure so no.
Just get an elbow, straight or bent, both end should have unobstructed airspace of at least one diameter in front of them, also must not get too near any walls of the box.
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
