littleitaly1990 Posted December 9, 2007 Report Posted December 9, 2007 I have infinity kappa perfects hooked up to a rf p500-2(specs are below). I've barely played them and the left speaker already sounds all f'ed up. Why could this be?.... The polarity SHOULD be good, but the rca's might not. speakers: SPECIFICATIONS General Power Handling, RMS 100 Watts Power Handling, Peak 400 Watts Frequency Response (±3dB) 75Hz - 23kHz Sensitivity 90dB Impedance 4 Ohms Crossover Frequency(ies) 3.5kHz, 24dB/oct Mounting Depth 2-3/4" Perfect Mid-woofer, 1" Perfect tweeter Amp: Dual Channel RMS Power at 4 Ohms 125 W x 2 RMS Power at 2 Ohms 250 W x 2 Performance Frequency Response 20 Hz - 20000 Hz Crossover / Equalizer Bass Boost With Bass Boost Bass Boost Frequency 45 Hz Low - Pass Frequency 40 Hz - 400 Hz High - Pass Frequency 40 Hz - 400 Hz A vitrolic, megalomaniacal sadistic psychopath.
roscoe1129 Posted December 9, 2007 Report Posted December 9, 2007 just quick here check to see what your x over setting is at on the amp and there is no boost or any thing and your loudness is off on the head unit. also maybe a wire is loose and grounding out on the speaker..... Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
littleitaly1990 Posted December 9, 2007 Author Report Posted December 9, 2007 just quick here check to see what your x over setting is at on the amp and there is no boost or any thing and your loudness is off on the head unit. also maybe a wire is loose and grounding out on the speaker..... xover setting on the amp??? I turned of the MX on my head unit off so I have to go to slightly higher volumes before it happens. Its a problem with the bass, but I cant really describe what it sounds like. No wires were loose, and voice coil looked nice and shiny. A vitrolic, megalomaniacal sadistic psychopath.
littleitaly1990 Posted December 9, 2007 Author Report Posted December 9, 2007 about the amp.... I know how to set gain, but what about the other stuff...I have it on high pass, but what frequency should I put it to?....If I find my camera I will take a pic of how its set. A vitrolic, megalomaniacal sadistic psychopath.
Aaron813 Posted December 9, 2007 Report Posted December 9, 2007 By x over i think he is refuring to cross over setting
bigtimedesigns Posted December 13, 2007 Report Posted December 13, 2007 Hrz on those speakers should be set around 125HRZ-135HRZ on amp Visit My Website
