radone Posted February 24, 2012 Report Share Posted February 24, 2012 I just received my DD-1 today and cant wait to use it. I have two questions after reading the manual. If I'm testing just a headunit thru the rca connection do I have to use a y-cable for each set of rca's or just the left or right rca or do I need to check all 6 rca connectors? When testing a headunit through an amplifier do I need to disconnect the speakers? Thanks Quote Link to comment Share on other sites More sharing options...
OrionStang Posted February 24, 2012 Report Share Posted February 24, 2012 For just the headunit, just check one rca plug. Disconnect the speakers. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
ineeDBass419 Posted February 24, 2012 Report Share Posted February 24, 2012 i found it easier just testing it through the amp Quote xbox 360 gamertag-greenrocks420 Not insulting you or anything, but did you just call us "bloody winging fairies" ? Link to comment Share on other sites More sharing options...
OrionStang Posted February 24, 2012 Report Share Posted February 24, 2012 i found it easier just testing it through the amp Agreed. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
kickass audio Posted February 24, 2012 Report Share Posted February 24, 2012 you dont have to get an adapter for it. What i did with my dd-1 and cc-1 was clip the negative lead around the outside part of the rca and hold the red probe off the tool to the middle (longer) part of the rca. I played the test tones and figured out the clipping and all that. I also just to make sure it worked the same checked my headunit through the amp just like mentioned in the manual with the same results. Some rca's you can just plug straight into the dd-1 and cc-1 however i found that only RF rca's fit in the opening as most other manufacturers have thick outer terminals that wont allow it to go into the rca connector on the tool itself unless i drill out the case on the dd-1 and cc-1 but im still skeptical about doing that and ruining such a great product. Quote 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress Link to comment Share on other sites More sharing options...
