Robert8252 Posted February 25, 2012 Report Posted February 25, 2012 This is mainly for Tony, Ray, Steve, etc.. Not looking for input if you can't give me some direction. So here's the problem. Here's my setup HU: Pioneer AVH-P5200 PAC LC1 inline RCA control Audison 2.9 http://www.audison.eu/download.php?file=assets/p_1315389315_audison_LRx2_9_tech_EN.pdf&name=lrx_2.9_tech_sheet_tech_sheet Audison 5.1K http://www.audison.eu/download.php?file=assets/p_1315389320_audison_LRx5_1k_tech_EN.pdf&name=lrx_5.1k_tech_sheet_tech_sheet Here's whats going on. Head unit only clips on 0db 40hz track at 37 out of 40. All others go to 40 out of 40 fine. so I'm using 35 as my max volume. The 2.9 runs my midbass. Then the 5.1k run my tweets, midrange and subs. Everything set fine with a 1khz tone and double checked midbass with 40hz. Then I try to set the subs and no matter what things act weird. Once it hits distortion it loses the tone but distortion stays and the amp starts buzzing. Even if I turn the gain down or up it doesn't change. I have to pull the RCA out to get it to stop and every way I've tried same result. Here's what I done. Checked all wiring Checked all connections Tried different rcas Different level tracks Different ground points with the dd1 So I tried to get it set to where it was distorting by guessing a little bit. Let it light up, remove dd1 and back down a little, but then I went for a drive and the amp is saying its overloaded. I'm guessing something is hurting he signal but don't know where. But here's a video of it. And yes wiring looks like shit because I've been checking it all and it's 10 degrees and snowing. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Ray Posted February 25, 2012 Report Posted February 25, 2012 Try it in the neg spkr terminal on the amp. And move ground to amp ground please. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Robert8252 Posted February 25, 2012 Author Report Posted February 25, 2012 Just did it. Ground at the amp ground input on the wire. Volume 35. Sub level +2. Ground and positive speaker input register but do the same thing. Although I noticed even without the dd1 hooked up knowing where the dd1 is lighting up distortion. I can her the amp start the buzz or humm at that point even without the DD1. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Ray Posted February 25, 2012 Report Posted February 25, 2012 I saw an audio control piece What is it? What is your exact input voltage to the sub channel? Over 5v? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Robert8252 Posted February 25, 2012 Author Report Posted February 25, 2012 Epicenter isn't hooked up at all. No power no RCA. Head unit is supposed to do 4v max output. Sub RCA didn't clip til 37volume at 0db. Using -5 at 35volume. Haven't measured RCA voltages will a multimeter on the end of a RCA be able to tell me that correctly? Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Ray Posted February 25, 2012 Report Posted February 25, 2012 Start with the basics. Try no lc1 So straight from deck. Try vol at 30 Meter the rca voltage on a 0db test tone. With no load hooked up see if you can go 3/4 gain on the amp. Without any buzzing. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
MuRKRoW Posted February 25, 2012 Report Posted February 25, 2012 By watching your video, I really think you should redo your ground. Did you just solder it to the rear seat closing bracket? I would put a ring terminal on that wire and then I would sand down a small area to bare metal. Then use a self tapping screw and screw down the ring terminal to that bare spot. If i'm just blind, ignore this lol. I think grounds are a really common place to get feedback so I would check everything you can. Quote Sound Solutions Audio ZCON 18 Crescendo Audio BC3500D JVC KD-R80BT headunit Alpine/Pioneer mids & highs 4 group 34 agm batteries Knukonceptz 3x0ga. terminals Kicker/XS Power 0ga. wiring
Ray Posted February 25, 2012 Report Posted February 25, 2012 Thats just the dd1 ground ref. Just hard to believe a 5.1 is bad straight from audison. Their failure rate is 1:200,000 Could happen but i just wanna go over all the tests first. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Robert8252 Posted February 25, 2012 Author Report Posted February 25, 2012 Alright. Did everything. Have the scratches and cuts to prove it. Disconnected lc1. RCA is straight from head unit to amp. Nothing in between. Volume: 30 Sub level 0 40hz 0db test tone Same thing except I could turn the gain to about 5/8 way this time instead of 1/4. But did exactly like before. Did it about 5 times from pos to neg. didn't matter really. I did notice when it lights distortion and it doesn't detect the tone if I keep turning it up a little more it finds the tone again but doesn't fix the distortion or amp acting up. Distortion stays on until I restart. No way to back off, it doesn't go off. So. Set it to volume 35 sub level 0 0db tone. Drove around for about 10 minutes full volume and it was good but really lacking compared to what it seemed earlier. Again. Not sure of it was gained right since it isn't working properly. Just by turning the sub level from 0-2 made a huge difference and I don't think it's into clipping yet but I also know that I don't know that. Lol. But then after a out 10 minutes i put the sub level at +2 and maybe a minute went by and the amp started flashing overload but it doesnt shut down just keeps flashing got home, turned the car off and then the 5.1 shuts off except the fuse good light stays on and the fan kicks on and doesn't go off. Waited about 2-3 minutes and just disconnected it from the battery for tonight. So. Done for the night. Work out of town tomorrow and Sunday but hoping to have a little down time at night if there's anything else to try. And in the vid the ground you saw I think is the DD1. Amps are grounded to rear batt. I have beyond overkill electrical for this system and solid connections. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Robert8252 Posted February 25, 2012 Author Report Posted February 25, 2012 And maybe I'm just a dummy but I couldn't get voltage to read from my RCAs no matter what. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
