By the way its for my home, I'm powering it with a powersupply
If you're gonna use it for home, I wouldn't recommend using a car amp on a power supply cause that usually doesn't work out well(distortion, not enough power cause a 400 watt psu won't do 400 watts on 12 volts, etc). You should save up for a professional amp people use for PA systems, or a plate amp to power that sub.
Edited by Omega5002
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Wow how the heck would I do that, so both the subs are going to be at 1 ohm putting out 600 watts each?
No, they will be at 2 ohms each and putting out what the amplifier sends to them.
Hammerdown... 1%
Just make sure you set your gains correctly, and build a nice box. i have a feeling the subs won't really like the extra power too much.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
