Here we go:
MP3: MPEG-1 or MPEG-2 Audio Layer III, more commonly referred to as MP3, is a patented digital audio encoding format using a form of lossy data compression.
It is a common audio format for consumer audio storage, as well as a de facto standard of digital audio compression for the transfer and playback of music on digital audio players.
The use in MP3 of a lossy compression algorithm is designed to greatly reduce the amount of data required to represent the audio recording and still sound like a faithful reproduction of the original uncompressed audio for most listeners. An MP3 file that is created using the setting of 128 kbit/s will result in a file that is about 1/11 the size of the CD file created from the original audio source. An MP3 file can also be constructed at higher or lower bit rates, with higher or lower resulting quality.
-->The compression works by reducing accuracy of certain parts of sound that are considered to be beyond the auditory resolution ability of most people. This method is commonly referred to as perceptual coding.
It uses psychoacoustic models to discard or reduce precision of components less audible to human hearing, and then records the remaining information in an efficient manner.
AAC: Advanced Audio Coding (AAC) is a standardized, lossy compression and encoding scheme for digital audio. Designed to be the successor of the MP3 format, AAC generally achieves better sound quality than MP3 at similar bit rates.
AAC supports inclusion of 48 full-bandwidth (up to 96 kHz) audio channels in one stream plus 16 low frequency effects (LFE, limited to 120 Hz) channels, up to 16 "coupling" or dialog channels, and up to 16 data streams. The quality for stereo is satisfactory to modest requirements at 96 kbit/s in joint stereo mode; however, hi-fi transparency demands data rates of at least 128 kbit/s (VBR).
AAC is also the default or standard audio format for iPhone, iPod, iPad, Nintendo DSi, iTunes, DivX Plus Web Player and PlayStation 3. It is supported on PlayStation Portable, Wii (with the Photo Channel 1.1 update installed), Sony Walkman MP3 series and later, Sony Ericsson; Nokia, Android, BlackBerry, and webOS-based mobile phones. AAC has also seen some adoption on in-dash car audio especially on high-end units such as the Pioneer AVIC series.
Now that's why i keep most of my tracks on .wma or .aac with 128~160kbps for highest quality, as you read the mp3 "works by reducing accuracy of certain parts of sound that are considered to be beyond the auditory resolution" and also reducing the size of tracks but since storage size isn't a matter to consider nowadays... (it was in the past).
So, the results from an original .wma 96kpbs converted to .mp3 128kbps will be 'good' and but will sound better when converted to .aac 128~160kbps.
if it was originaly at 96 try to convert it to 128~160 max. which is the best for quality. Like Nesto said, softwares will always alter the file and will alter even further when converted to higher bitrates and can/will even clip the tracks. It happens.
Just caught something there, you cant upgrade the quality of a song, like you said 96 to convert to 128~160.
Once you go down you cant go back up....
Actually you can but i don't recommend goin back and forth converting multiple times the same file. Like i said, if it was original 96Kbps regardless its extension, just don't stress it too much and convert to what it's the best for quality/size. If you really want to convert to higher bitrates, fine. Not saying that this is the best way to store and keep your tracks but just my personal way and i found no problems with quality or clipping so far.
Input was .mp3 128Kbps (5,25Mb):
Output is .aac custom bit rate set to 160kbps (6,15Mb):
*This a cool software btw and you can find it at:
http://www.softpedia.com/progDownload/Total-Video-Converter-Download-25681.html
Edited by Vanni_Bass82
I wanted to add something, since you are going to use your ipod anyway as a music source then the Line out is the best way to go. This way you dont change volume levels by accident at the source and risk clipping. This way when you set you gains they are set with the same source level. like others have said if you must rip rip at the highest bit rate.
You could even play your test tones on your ipod and use the line out with a headphone to rca cable and hook that cable between your ipod and our dd-1 to make sure it isnt clipping. if you get clipping then try the headphone out at a volume level that doesnt clip then never go above that volume level again after you hook it to your HU.
Edit*
I missed that you have a USB port on your HU, so just use that instead of line in.
Edited by strangeduck
Wow. Short and sweet. iTunes music quality is a joke. I'll only buy rap songs from them. And as far as quality goes. If you're ripping a cd in iTunes go to the preferences and set it to rip in apple lossless format. It's the "same" as flac. No two tracks will have the same bit rate and range from 10-30meagsbytes a song but it is the closest a digital version can get to original quality. Some people are fine with 320 mp3s I just feel therei a big loss of high frequencies that many will probably not notice. But if you want the best possible quality for your iPod use lossless and hook the ipod up to USB of the head unit.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Rip to Apple Lossless in iTunes, or to WAV which will play on most anything.
and stragneduck, using the DD-1 to test your player... genius.
2007 Pacifica
Music will always be recorded at different levels, that's why bass heads seek out the loudest songs. :)
(this is why apple has the "check volume" feature, to lower all musics level so there less of a difference from quiet to loud songs. again, "check volume" will lower the overall volumes)
The CD should be 1411kbps, so anytime you "Rip" it besides Apple Lossless/FLAC/WAV you are lowering quality, albeit a test tone.
320kbps mp3 is fine for everything, most cannot even tell the difference from 192kbps to 320kbps, the largest difference with be the subtle nuances present in the upper frequencies.
I'm not sure whats going on but you shouldn't be able to up the quality, that makes no sense. you cannot create more data, you can only downgrade the quality. regardless what the program above does.
If you plan on using a digital device I would download the tone from the website, or have a trusted individual make one in whatever format you want. :)
I recommend ripping in 320/256kbps mp3, its the most versatile format and very few will notice the difference from CD quality. If you have bass blasting shaking your car to pieces you arent going to notice the difference, unless the CD source is louder than the IPOD/USB/SD/AUX source.
  • Who's Online   0 Members, 0 Anonymous, 1907 Guests (See full list)
