i just got around to remeasuring my car and this is what i came up with. 16h x 30 width x 38 depth. subs are going to be 2 obsidian 15s, subs up port back. was going to do areo ports but now that i found more room i think i can go with slot port and will also be cheaper! its going into a civic hatchback with no back seats. should i do a bottom port ( whats in the screen shot) or do a port with 0 common walls and put it in the middle of the box. it will have about 6-8 inches from the hatch but could also go more if i slide the box closer to the seats. how does this design look using a bottom port?
EDIT: i wouldnt have crazy loading issues with having the subs slighty off set would I? because 30 width wouldnt fit them side by side
Edited by mattc3366
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
2 15s? id go a little more port. like 15 or 16 per esp if your tuning at 33 hz
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
wait, how is the port running the entire width of the box yet its only touching 1 side? thats impossible. if its an L-port then it has to be touching 3 sides.
edit: i'd also throw in a little bracing, it never hurts
Edited by Kranny
x2 just saw that.
so what should i have for common port walls? sorry guys lol
I just tried 3 common walls and it brought my volume up and didnt really affect tuning and my port area
Edited by mattc3366
New build :
same amp
i found out why i had that to 1 common wall lol. i seen that it said bottom port but didnt bother to load the pic and see that it wasnt touching the sides.
New build :
same amp
you cant just guess on the common walls. it tells the calc how many sides of the box the port is touching. put 3 in if you put the port on the bottom/top/side of the box and it touches three sides. its really simple, i dont understand how people fuck up on that part. if the port is in the middle and doesnt touch any walls, then its 0.
heres the new one.
New build :
same amp
The problem with the slot is that takes up more volume and does not allow for easy and nice vertical crossbracing.
well if i use wooden dowels i could just drill a hole through the slot port and glue and seal it to the port right? then that would brace the box and the port aswell i would think
New build :
same amp
