I'm so lost! H/u power loss
Loudness: Mid (without it I get hardly any bass)
Subwoofer 2: 125 hz (currently +6)
I think those would be the only two that effect sub? Any other ones you can think of or need?
turn loudness off... no matter what you think, turn it off. its only meant to be used on low volumes
Why at 125hz? How about 80/100hz instead, cant imagine the subs enjoy playing that high.
Sub level should be at 0. When I had that unit I could go 38 clean. Last few volume clicks accounted for more than 1volt of signal.
reset everything with EQ flat, no bass boost, using -5dB or -10dB. you might have been used to a lot of clipping with your previous setup.
Edited by Decaf
Thanks a lot decaf, I'll go through and do it tomorrow. I'm in class till 10 tonight so it will be a little cold and dark. I could go up to 58 out of 62 with a clean signal
If I remember the mvh goes up to volume 40. most newer pioneers that go to volume 62 are clean to volume 58-62
make sure you are not using no bass boost on the headunit either
-5dB is quieter but safer
-10dB is whats recommended for most users.
if you play my crap you should use -5dB
Edited by Decaf
What kind of music do you make?
Yeah this one goes up to 62.
disregard it, i dont make anything....
if the mvh goes to 62 and you tested it clean to 58 then use 58. if you have speakers hooked up the the headunit then thats a different story, you can only go up as high as they sound good. you can use the dd-1 to test the headunits amp if you disconnect the speakers.
decaf FTMFW!!
edit: had ta remove some stuff lol
how about a bad set of rca's? i know if you only hook up 1 channel to a sub amp usually itll be quiet as hell....had that happen with my setup and it sounded like ass..... try a different set of rca's
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
  • Who's Online   0 Members, 0 Anonymous, 1016 Guests (See full list)
