The Wagon, two 12's, few thousand watts.
would have gone with a single battery, and cables connected directly to the amps, but the battery doesn't fit under the bonnet :P
was going to run the cables from the front battery, straight to the rear battery, then run cables from the rear battery to the amps, but it meant more fuses, more cable, and a non removable rear battery.
great numbers from those pioneers!
looks like you're using 4awg for the batteries?
LMAO and did you just stick the fuse directly on the battery termina? never seen that 1 before.
don't think it would be a problem though?
that's music... and the box is now bolted to the floor.
car peaks at 39Hz, Thug Motivation is 40~41Hz.
If I get some suitable, 39Hz, music, it should do the 150 playing music ;)
does it on tones.
Good seeing another Aussie on here, I would be pretty happy with that score but so close to 150, maybe if you slowed thug motiviation down enough so its 39Hz?
Just curious where did you get your d3100 from and how much? just wanna compare prices.
