box desigh
gusto42o
I got one DD3515 1700 watt wondering if i could get help with a box design tuned to 36. for a explorer sub and port up maximum dims 20 height 20 depth must be 39 wide 45 degree corners net volume 4.50^ft port area 72.0 . THANK YOU
Here is a suggestion, port up/sub up and on your dims, suggested manufacturer specs were used:
Enclosure Specifications:
Fb = 33.034 Hz
Vb = 4.499 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 20 in
External Width = 33 in
External Depth = 20 in
Port Width = 4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 33 x 20
Left & Right Sides = 18 1/2 x 17 3/4
Front & Back = 33 x 17 3/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 18 1/2
Extension = 11 1/2 x 18 1/2
Note that DD subs are usually tuned higher, consider researhing more into that.
Some bracing applies, let me know if you need an assembly guide or have any questions.
OP, shoot me a PM for a real box design, rather than that copied and pasted junk.
you're going to need a little more support for that big of a sub.
i'll give you a 3D model too so you can see exactly how it goes together
like so:
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • 3 weeks later...
bump
Would you like other suggestions?
You can also request a design from Teardrop in the thrad he has setup.
  • Who's Online   0 Members, 0 Anonymous, 406 Guests (See full list)
