Need help asap!!!! Wats my box tuned to?
Maybe u could keep the box if you don't use subs that need as much volume.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
yeah if it has bracing i'm guessing 25-26 range. really low...
Damn that's low , he lied and said it was 35hz. Can you tell me how cubes each sub gets and wat to cut the port down to tune it to 33 hz.
3.43 per sub and the length of the port is 7 in for a 33hz tune
Wow y only 7 that seems to short, to cut from 22.5 all the way down to 7 I would ave thought maybe like 12 to 15 or something.
Also don't dismiss that your port area is too low by a large margin, you will still have a faulty design even if you retune.
There's still a lot of port area missing, the holes are cut for 12s, etc. Would be louder if you made your own
I mean The way the box was made you can't cut the box and open the port up some more, originally his port area was 19w 2.5h then he cut it to 4.25 in height. No if I'm correctly your supposed to have between 14 to 16 cubic ft of port depending on the cubic ft in the box, so let's say it's 6.4 per chamber so take 6.43 times 15= 96.75 per side . So total port are for this box needs to be 193.5
Then it if cut and open the port to 5.1 instead of 4.25 were it is now that puts me at 96.9 per side. Then I would cut the port down to watever it needs to be to get to 33 hz instead of 24.
You say per side, so there is two 4.25 by 19 ports? That would change a lot of things
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
Yes it's two ports, sorry I didn't mention that
LOL... you just happened to miss you have two ports.... you are tuned to about 34Hz then, each sub get about 2.9 cubic feet. port area 1s 161 sqin.. and everything looks much better
Edited by Joe X
Then it if cut and open the port to 5.1 instead of 4.25 were it is now that puts me at 96.9 per side. Then I would cut the port y
How is it only 2.9,,,,, 43 times 33 times 22= 31,218 diveded by 1728= 18.06 and my net would be 14.8. Divide that by 4 and u get 3.7 before displacements.
  • Who's Online   0 Members, 0 Anonymous, 1019 Guests (See full list)
