free box designs with a sketchup pic or file
teardrop
i need a design for 4 orion hcca 15s. using 4 hcca 5000d's for amps and need about 32-34 hz and i want sub up port back. i have alot of room as its going in a ford excursion.
sub displacement - .37
i would like about 4.5 cubes each
and for the port it says 16x3 inches but that seems pretty small.
i don't know if you do bandpass boxes, but if you do i need a design for a mayhem 12''. its for a 95 Honda civic max dimensions are
(LxWxH) 35x22x16.....thanks in advance
woofer specs
Coils Dual 1 Ω / Dual 2 Ω
Re0.7 Ω / 1.4 Ω
Fs40.7 Hz / 39.7 Hz
Qms5.16 / 5.28
Qes0.23 / 0.22
Qts0.22 / 0.21
Mms201g / 211 g
Sd480 cm^2
Vas24.5 l
SPL90.4 / 90.4 1W/1m
Bl17.7 / 26.2 Tesla Meters
Xmax30mm (one-way)
RMS2500w
Ported enclosure 1.75-3CF
Mounting depth 7.75"
Driver Cutout Diameter 11.150"
Driver Overall Diameter 12.500"
Driver Displacement 0.18 CF
Weight 65 lbs
lol there's a few different types of bandpass boxes
i realize that when i did my research and i think a 4th order will work because i want it blowing through my rear deck of the car
  • 3 weeks later...
4th order, 12" DC level 3, Maximum dim: 34x15x22ish
Sub displacement: .32
Tuning preference: Whatever you think sounds good for rap.
Being overpowered.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
So I have one for you. 2 Fi 15" BTL's, parameters below. I have the basic parameters of 46" Wide x 35" Deep x 16" High using 1" MDF I want about 32HZ tuning slot port. Thanks. Oh going to be running 2500 watts per sub.
Bone Stock 2006 Dodge Magnum SRT-8
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
