free box designs with a sketchup pic or file
teardrop
Nice thanks buddy that's awesome can those ports face the front so I can seal the wall off? Thanks again your a big help!
yea they will have to bend but yes they can come out the front they just need to be 13 in long
I see the ports are 12.25" and the depth of the box is 16.5" so the ports will fit but will it affect the tuning but I can't wait to get started now looks sick.
sorry i goofed that port length its suposed to be 13 i dont know how i didnt catch that
4 spl audio sp3 12's (dual 2 ohm) 1000watt Rms(pair) Max dimensions: 4ft wide 3ft tall deep as needed Sub specs: Fs (hs): 26.3 Qms: 769.5 Vas (ft): 2.111 Xmax (mm): 13.25 Qes: 0.778 Bl : 13.05 Qts: 0.706 1000 Rms 2 Punch T1 1500's for power if needed I'd like it in a wall. Port & speaker placement doesn't matter. Just want it loud, low, with good sound. It's going in a Yukon. Thx
whats your sub displacment
So will the 13" inch ports work in the front if the depth is 16.5" or do I have to keep the ports away from the back wall? It would give me 3.5" off the back wall or just use an elbow and aim them at the subs? Sorry to bug Ill leave you alone after this one haha!
current score-156.6 sealed on the dash
4 ZV3 15s
1 AB 1100.1
I have one SoundStream SPLX-HF 15". Running on two SoundStream TX1.1300D (one per coil) going to seal off from trunk. I want sub and port facing forward. It is going in a ford contour.
Max dimensions are 39w X 31L X 22H
Specs on sub are:
series wired SPLX-152HF
Fs (hz) 35.96
Qms 6.476
Vas (ft³) 87.56
Cms (mm/n) 0.0794
Mms (g) 247.1
Xmax (mm) 13.00
Xmech (mm) 19.50
Piston Diameter (in) 13.19
Sd (in²) 136.6
Qes 0.503
Re (Ω) 2.95
Z (Ω) 4
BL (Gauss) 18.09
Rms Power (watts) 1,250
Qts 0.467
NO (%) 0.78
1w/1m SPL (dB) 90.95
Voice Coil Diameter (in) 3"
Impedance (Ω) DVC 2Ω
M-vd (ft³) 0.298
Measurements SPLX-152HF
Overall Diameter 15.25
Overall Height 9.25
Mounting Depth 8.375
Cutout Diameter 14.125
Motor Diameter 7.875
Motor Height 3.5
Flange Width 0.75
Flange Height 0.625
Weight (lb). 35
I want tuned to 31 hz
Sorry I'm still new 2 this stuff. I think this is what u mean.
2cu ft ported factory spec
Overall diameter: 12.626
Overall height: 7.5
Mounting depth: 6.75
Cut out diameter: 11.125
Flange width: 0.75
Flange height: 0.75
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
