How to find resonant frequency
IKnowImLost224
there are a lot of options. most people fire everything back. its the simplest and i would recommend it. firing forward with the trunk sealed off from the baffle is the best method for just getting louder, it just takes more work and sometimes cutting metal. ive seen great numbers from one member here with a port going through the arm rest and sub firing up. but he built a new box every month and really played with everything.
I'm not looking to win comps or produce the biggest numbers lol, just want a good loud system. If this trunk wasn't so stupid I would try doing more but its tough cause I only have about 32" width to play with and the bottom of the back window is curved so that cuts down on what I can do with height and depth a lot
just because you used torres to tune doens't meand its done right. don't build vented boxes with less then 14 sq.in per cu.ft. simple. subs needs to breath! NEUMAN
then what about aeros? they need what, 8-12ish sq in
R.I.P!
(Nov-29-2009)
92 explorer
current build
How does this look for a RE XXX 15?
Edit: Everytime I try to post a screenshot it wont show after I submit the post
Yeah. Is it 8-12 or 10-12?
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
it needs a host site. post it on photobucket or something then post the image link here.
i would be willing to bet that an aero wont work in his setup. very hard to get the port area and tuning you need within a tight space. but worth looking in to
  • Who's Online   0 Members, 0 Anonymous, 2524 Guests (See full list)
