How to find resonant frequency
IKnowImLost224
I have no idea why its so small. Also wanna know why I dont have a complete cut list? There is no cuts for the port pieces
just because you used torres to tune doens't meand its done right. don't build vented boxes with less then 14 sq.in per cu.ft. simple. subs needs to breath! NEUMAN
then what about aeros? they need what, 8-12ish sq in
Yeah. Is it 8-12 or 10-12?
thank you. i wouldn't have been able to aanswer that question. i have never played with aero's. so if one was to not use areo's would they figure the same port area of 8-10/10-12 for round ports? please advise. PM if you want. just i normally build sealed or vented. not many true ported box leave my shop.
NEUMAN
I would do aero ports, they dont need much port area because they are so efficient, they only need like 9-12 sq ft because of the round design and flare ends. But the down side is cost.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
What are your max dimensions can you do? Cause with a l-port you box is gonna need to be a bit bigger so after displacement you can have a minimum of 4 cubes.
Kenwood H/U
1/0 wire,
Max dimensions are pretty close to what I have in the pic of torres. Its hard to come up with an exact number because of my rear widnshield. It isn't flat at the bottom its kinda curved so it really cuts down on what I can do as far as dimensions.
This is the box I just built for the XXX that sounds like shit
This is some 9500's I wish I didn't get rid of
And a box I made for my Type X that I couldn't remember how I got it in the trunk so I ended up having to cut it out. (First box I ever made)
I posted these other pics so you could kinda see what I was referring to as far as the curved windshield
you got plenty of space in there to be honest haha make box wider ..... better off what are your dimensions as is
R.I.P!
(Nov-29-2009)
92 explorer
current build
Only problem with making it wider is it makes it difficult to get it in through the trunk because of how the taillights are. The width between the taillights is about 32". Box dimensions right now are 30x15x20
i see the problem now ... does your seats fold down?
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2524 Guests (See full list)
