michigancapri92 Posted February 29, 2012 Report Posted February 29, 2012 OK starting to plan build and want to make a good box design for 2 12" DC lvl 3s . Center Aero ports tuned 34 Hz will be behind front seats facing forward and bracing will be dowel rod please let me know what size and where, I have the depth and height set don't know what width and ports for good size and tuning here's demensions Top depth 14.5 Bottom depth 17 Height 16.5 Max width 40 Going to be 3/4 inch birch double baffle Let me know and thanks so much for help Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Joe X Posted February 29, 2012 Report Posted February 29, 2012 You usually don't implement a slot port end in a slanted face.
michigancapri92 Posted February 29, 2012 Author Report Posted February 29, 2012 That's why I'm doing center Aero ports Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Joe X Posted February 29, 2012 Report Posted February 29, 2012 That's why I'm doing center Aero ports Sorry, checked and a single 6 aero would work in the center with a 16" length going about 2" external. Explore other options using the Torres box calculator. Total driver displacement is 0.32 cubic feet. Target internal net volume = 3 cubic feet Dims I used = 16.5x33x (14.5,17), port 6" diameter 16" length tunung 34Hz. If this is some help.
michigancapri92 Posted February 29, 2012 Author Report Posted February 29, 2012 I would use Torres but only have android tablet ATM so can't use Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
