bass_stalker Posted February 29, 2012 Report Posted February 29, 2012 would there be any bad effects of changing my headlights from a 35 watt sealed beam to a 55 watt sealed beam. these are the ones i currently have http://www.autozone.com/autozone/parts/Sylvania-Headlight/2000-Jeep-Cherokee-2WD/_/N-je9faZ9ci8c?itemIdentifier=374009_0_7179_ and these are the ones i'm looking at getting http://www.autozone.com/autozone/parts/Silverstar-Headlight/2000-Jeep-Cherokee-2WD/_/N-je9faZ9ci8c?itemIdentifier=412572_0_7179_ JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Azagtoth502 Posted February 29, 2012 Report Posted February 29, 2012 Wouldn't last quite as long, but would be brighter. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
bass_stalker Posted February 29, 2012 Author Report Posted February 29, 2012 so it should be fine on a stock system? oh also is 4k a whitish colored light? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
SmallTruk Posted February 29, 2012 Report Posted February 29, 2012 so it should be fine on a stock system? oh also is 4k a whitish colored light? It'll be fine, it's the same wattage as high beams. Yes, it's white. Not HID white but not a typical halogen yellow.
El1T3Bass Posted February 29, 2012 Report Posted February 29, 2012 why not just convert to HID's? it will be way cheaper... wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
1stgen Posted February 29, 2012 Report Posted February 29, 2012 why not just convert to HID's? it will be way cheaper... because his lens's are his bulbs , and that would take more work then a usual hid kit , not worth it lol
bass_stalker Posted March 1, 2012 Author Report Posted March 1, 2012 why not just convert to HID's? it will be way cheaper... i'll link you to my reason lolhttp://www.futurevisionhid.com/h6054-200mm-hid-projector-headlight.html i dont have a job so there is no way i can save up 500+ dollars, in comparision i can cut a few yards and get 50 dollars to get those sealed 4,000k bulbs to replace my 3,100k's JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
