I need a design on a truck box. The sub is going to be a fi bl 12", amp audioque 1200d, i just want a design thats going to be loud to the ear, i only listen to rap/hip hop. I would like to stick to a slot port.
The space its going is here, sorry its dirty lol, and im taking out the tool box things
height: 14"
top depth: 6"
bottom depth for driver and passenger side: 11"
back length: 59"
front length behind passenger seat: 21"
front length behind driver seat: 21"
behind center console depth: 5"
behind center console length: 18"
kinda of a weird design... if you need more info i can get it
Edited by fi audio
Setup:
Headunit: 7" indash screen
Sub: fi bl 12
Amp: Audioque 1200D
Box Ported tuned to 34hz
Big 3 done in 1/0 gauge
are you looking to hit really deep bass notes or more medium to high bass notes?
name off a couple songs you would plan on playing so i can see what hertz your box should be tuned to.
Edited by smceachran
just mediums and high bass notes for the most part i know i have the one in my other truck tuned to 32hz.
i usually listen to
gucci mane- pyrex pot, yella diamonds and some others
some lil wayne- fire flame, 6 foot 7 foot
waka flacka flame- hard in da paint, oh lets do it
machine gun kelly- wild boy
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
i cant managed to make a good design that gives you a good amount of port area per foot. you should try using the box calculator torres has on the subwoofer forum. it helps you create your own sized box based on your knowledge of your truck. im not too good at making a box out of just specs id need to see it up close. sorry lol.
its fine man. Its kinda of a pain cause the center console has to be built around it
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
ya thats what was really killing me. i wanted to try and make a small section that ran off of the side of the main box just for extra volume in the box, but due to the small space caused by the console i couldnt get anything good.
if someone could design a box like this that would be cool if the box needs to be a little bigger behind passenger seat i still have room to move it up.
i can figure out a simple box easily but i dont know how to use a calculator when it aint just a regular square box or angled box
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
Ok i know how to get net volume if I break it up but how to I add in port then
Setup:
Sub: fi bl 12
Amp: Audioque 1200D
