So this year Polk Audio amps are no longer strappable......and after many hours of discussion on this with reps, techs and the build house they will be soon but as of now the shipment I'm receiving won't be. So what I need is info on Hi-fonics Maxxlink MLX-100 or preferably another product that will do the same. I will be running 4 PA1000.1's and replacing them as soon as the strappable version is available so I don't want to drop 500 on something that will be used for a few months. I'm thinking the Maxxlink is the way I will be going but I'd like to get opinions on it if any or if someone has used something else for maybe a little more cash.
MAxxlink has had major problems be very careful.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Any suggestions on a viable substitute? I've been wracking my brain for an easy solution but all I can think of is a parametric eq (soundstream, clarion ect) with sub control for bass knob, gain matching and praying for the best lol. Any other ideas?
Edited by larrys95civic
cc1 and dd1 problem solved.
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Oh yeah thats a must, but what I'm looking for is control of my amps besides an inline rca bass knob.
Like with your mind? :o How else are you able to control your amp's? Sorry.. Hence the name.
I'm pretty sure I am just putting to much thought into a problem with a simple solution. But here is what my issue is. Ok when you strap an amp you have a master and slave, master controls all and gives you matching setting for your slave amp. Well when wiring them you gain the others impedance, so if you wire both to 2 ohm you end up with a 1 ohm load. From what I understand of the Maxxlink it works the same way if your amps can not be strapped. Taking n8balls2013's advise of this being an inferior product I was hoping for suggestion of something that would work along the same parameters. And that is it in a nutshell LOL>
Bump for this feller, I'd like to know as well.. still learning. Would be a great read.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
