When you create a double baffle, is it better to attach each layer seperatly to the box or do you laminate them first and then attach it as one unit so the screws go through both baffles into the box.
Also, whats the best way to attach mdf trim panels to seal the baffle from the rear (wall). What do you use to seal around the mdf and headliner/trim panels? Thanks
Edited by Amart88
its easier to do them seperate I feel.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I say do each seperate
Yeah, thats what I was thinking too but just wantes some input first. Think it would look cleaner also.
and tips on adding trim around the box to finsh the wall and seal from back? :)
Built the "shell" of the wall to your vehicle instead of just puttiing a bix in and sealing it off
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Yea that's what I hoped to do but I got pretty limited space (2 door pursuit) If I build the whole baffle to fit the car it won't fit in the door :( drawbacks of smaller car. I already have the box in final stages 8-9 cubic feet for 2 15's. I got about 4-5 inches on top (center) and about 2 on each side to seal up. Tricky curved angles with roof and side panels
