Box Help
Jonesy33
I have a dc level 4 10 coming and i wanted to see if I could get a box design. I own a 99 silverado single cab. My max dimentions are
height-22in
length-57in - i would like for it not to take up the whole thing I need room for my battery :D
bottom depth-8in
top depth-4in
:help:
Thanks
what are the dimentions of the batt and the only issue is that the woofer may be to deep for those dimentions i will hasve to check it out.but i can design one for you and make a cut list if you need it
90 honda civic lx 4 door
sony cd head unit
mmats mp5 eq/crossover/line driver
35 farad hybred cap
ppi sedona 430ix on mids/highs
hifonics brutus brz1700.1d @2 ohm 1200w rms
front/jl audio evo 6.5 components
rear/kove audio 2 way 5.25
subs/pioneer premier tsw3002spl 12x2 1000wrms ea 3000w peak
and a hi amp alt 160a
http://www.stevemead...0s-honda-civic/
you can get ahold of me on facebook under boom inc just im me and i will get back to ya asap
sony cd head unit
35 farad hybred cap
Lazie is correct, I have to use 1/2" mdf and a top depth of 5 and bottom of 8 1/2" i believe (its been a while) to fit a lvl 3 10 in my silverado. Its a crew not reg but same problem, very minimal room and thats what i had to do.
Sorry it took me so long I was at work.I could prolly add a half an inch to the bottom I'd that will help. I've put a sub that's been 7 inches deep in my truck before but my knees were in the dash. I'll prolly end up sanding the back down a little. The battery is 12"X6.5"X8.2". I'm not sure what it needs to be tuned at I listen to a lot of rap and also a lot of classic country. I that helps any.
Thanks again.
I checked with 8.5,4.5 depth and won't fit, you NEED a MDF ring to mount the sub (if that fits).
Motor width 7.75, Mounting depth 6.25 for the DCL4 10"
My ported box behind my seat of my Reg cab Sierra('03) is 7" top depth and 10" bottom depth. I've got airspace AFTER port displacing of 2.00 cubes internal. So half of the box length gives 1 cube(which should be spec for that 10) and plenty of room left for a battery.
  • Who's Online   0 Members, 0 Anonymous, 1254 Guests (See full list)
