as stated, my grounds are good, not loose. and only my mids highs amp is getting hoy. my aq1200d is good. its an mtx4320. what could be going on with it. like hot enough i cant rest my hand on it,like can smell the heat from front seat while its in trunk and backseats out
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
re-check the gains. could be clipping?
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
And check the speaker wiring. If you are running more than 1 per channel, then make sure they are not wired at too low of ohms. And check the voltage at the amp. You may need bigger wire with the watts you are trying to push. And then check your gains as stated above
Edited by sps1989
they arent clipping. the gins are all the way down. im running two per channel. set of fosgate punch 6.5s 4 ohms and fosgate prime 5.25s
and on the other set of channels i have a set of aq pa supertweets and a pair of american bass 6.5 8 ohms.
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
I have a 4 channel philips amp, there you can cooking a egg on so hot
but never a problem whit it
JBL
A lot of class abs get hot make sure power wire is the biggest you can use an put a fan on it..my zapcos use to shut off an still get warmg
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Thats a class A/b amp no? They get hot.. My sax125.2s get real hot.. Protect from the heat.. If the amps not going into protect i wouldnt worry
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i had 2 sets of american bass 6.5 and it was still burning up. so if its not going to protect its all good? its got 4gauge to it and ill get a fan wen i build side walls
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
  • Who's Online   0 Members, 0 Anonymous, 1266 Guests (See full list)
