crucial in car audio is ground make sure your grounds are good and tight
also take your time on wiring your headunit dont get wires mixed up
be careful and gentle with door panels ( stupid plastic breaks easy on most doors ) take your time dont lose anything( also dont forget to connect door lever common mistake )
rca's on one side power/ground/remote wire on the other side
disconnect your battery ( just do it completely to be safe )
make sure you crimp your headunit wires real good those wire pull out later your going be frustrated. also your ring terminals for your ground and power should be crimped good.
mount your amp and sub box down you dont want them sliding around unhooking and shorting out.
when you run your power wire make sure it through a rubber gourmet them wires eventually overtime can rub the rubber off and short out on body and if there is enough current/power going on it will start a fire.
take your time double check everything if your making your own box measure 3 times cut 1. Just take your time if you need help the whole forum is here for you at anytime.
say no to drugs. J/k i like to make sure i have everything i need , because when u need to buy something your car is disabled.
says you. i have no seats in my car but i still drove to ace for some screws :D
dont go to ACE go to TRUE VALUE instead
2 12" Jeff Vue Customs
1 set MB Quart FSB 216 in doors
1 American Bass 100.1 on sub
1 Hertz EP2 on doors
JVC deck IPOD control
Stock 105 amp alt
DD-1
big 3
new build in Chevy caviler http://www.stevemead...chevy-cavalier/
last set up in the ZX2 http://www.stevemead...-current-build/
old build log http://www.stevemead...-1998-ford-zx2/
Gold is the money of kings, silver is the money of gentlemen, debt is the money of slaves. Just my .02c
that shop needs keep those doors open so they have to charge for it
if people think 10k is a lot then they should get into other hobbies.. like masturbating, cause any hobby cost money to maintain
Lol no, I'm smarter than that bro haha. Fool me once, shame on you, fool me twice..............go fuck yourself lol
Take your time, be patient and be clean!!!
Duel Sa-8 V.2 D2 Sub Enclosure
2001 Pontiac Grand am
  • Head Unit - OEM
  • Processor - RF 3sixty.2
  • Subs - RE Audio SXX12D4
  • Amplifier - Kicker ZX1000.1
  • Mids & Highs- Rockford Fosgate Power T2652-S
  • Rockford Fosgate Power T1693
  • Mids & Highs Amp - Rockford Fosgate Power T400-4
  • Wiring - 1/0 AWG, 4 AWG, 8 AWG
  • Alternator - Stock
  • Batteries - non ext
  • Box- Absolute PSEB12BK
make sure your ground is not just a self tapping screw, it is a hole with a bolt and nut and star lock washers on both sides... and the ground should be at least a gauge larger than the power wire
Edited by JeremyN
Stock 105 amp alt
DD-1
big 3
