Voltage Question
so i just purchased a used XS D1200 and i hooked it all up so my question is do theses voltages look alright
All measured with a DMM
Resting with car off. 12.8-9
idle. 14.1-2
full tilt. 12.5-9
keep in mind i have stock alt and stock batt up front with only 4 gauge cca to the rear batt (the XS) planning on getting some better wire soon and the big 3 done.
thanks in advance!
Looks fine to me.
Full tilt voltage could be better - but it's not bad either. I would suggest getting a better battery up front - that's dragging down the performance of the XS battery (stock battery has lower resting voltage)
Also: what amp do you have?
12.8 - 12.9 is perfectly fine for a resting batt, bad is when it gets below 12.5v resting (usually needs a recharge/ reconditioning)
14.1-14.2 is fine also charging
full tilt volage in the 12s just means you need more alt/batteries for whatever amperage draw you have.
Ok thanks guys getting better equipment just gotta save up.
My amp is a kole audio hk1920 2 channel I think my amp and wires are next on the upgrade list lol
  • Who's Online   0 Members, 0 Anonymous, 1078 Guests (See full list)
