How do you guys do it? This is going to be my first big power (well, big for me) build and I need help learning to fuse for bigger power. The amp I will be using is a Stetsom 7K D and I'm buying dual inputs for it from Woofer Warehouse, so 2 runs of 1/0 each for positive and negative. Would I be able to get distro blocks that have 2 1/0 inputs and outputs and use two 240 amp fuses per block? Or do I need to fuse each run separately and try to find 480 amp fuses? Any input/tips are immensely appreciated.
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
fuse each wire alone. dont combine fuses and wire. i have always just done an in-line fuse on each wire.
So should I just run the 480/500 amp fuses on each block?
TEAM DC
that sounds like the opposite of what i said. you want to run a 500amp fuse to one 1/0 wire?
400 on each one.
EDIT: Depends how long the cable is. Probably just do a 300 on each.
Thanks for the help buddy. Runs shouldn't be too long, the longest would be from the front to 1st battery in the trunk.
TEAM DC
I thought thats what you were saying. Im going to fuse each run separately like you and OrionStang suggested, I just needed help figuring out what size fuses to use,
TEAM DC
just use 300amp fuses. you will be fine with that, and safe.
Thanks man will do.
TEAM DC
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
