RE 2006 XXX 12's Ported Enclosure?
Dozier
bump
Guest MegaloManiac
heres your box..and 25.00 to my paypal..
42 wide, 18 deep, 19 tall external. the 42x18 panel is 1 1/2 thick..ie: the the woofer mounting.  subs up port back
port is 16.75x5 wide and 34" long or deep" "
tuned to 36.3hz  6.46cuft before 4.279 after.
add bracing inside the box also.   i accounted for bracing..  should bump, 83.5sqin of port area.
have fun
Posted Image
good enough?
Awesome...Thanks Ray. Your my hero. I will post pics when I get it done in two weeks. Who knows...Maybe even a video.
www.AlabamaDrift.com04 Silverado in the works
I hope you have somebody to help you, since this is your first box..
not exactly going to be an easy one.
take lots of pics that way when its done i can help you take a look back at the build and maybe give some hints for you next box. "pointers"
Hey Ray, I have one more question. When putting the port into the box, should I put it on the right side and run the wall down the right until it gets 5 inches from the rear wall and then turn and go down the back side of the wall until I reach the 34 inches of port? And when measuring the distance (the 34 inches), the outer wall or the wall inside the box? Thanks. I am building it on the 23rd next week.
Also I have two US Amps AX3000DE amplifiers and those two xxx 12's. How should I hook them up? Series or Parrallel?
you measure from the middle of the port. and your subs are dual what?? 1ohm??
pretty sure you are gonna parralell them down.
I think they are dual 2 ohm voice coils. Hmm. Parallel, is what I was thinking though. Those amps are tough and I will only be running them about a little over half way each.
half way on what?
how do you know and they aren't hooked up yet?
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
