Dozier Posted October 31, 2006 Report Posted October 31, 2006 I am planning on building a box for my 2006 XXX's in my Explorer soon and I would like to have some opinions on the box. I am leaning towards a CRX box...Subwoofers firing up and port to the rear, with 6 cu. ft. of space inside before subwoofer displacement, and tuned to 36hz. Is this a good box or what? Any suggestions would be great. Also, where do I start on making my calculations of the box dimensions and port dimensions. I tend to be a little stupid with this stuff. Thanks. www.AlabamaDrift.com04 Silverado in the works
Ray Posted November 1, 2006 Report Posted November 1, 2006 a little more info, and you might get the help you need.. how many woofs how much power rms what is max demensions inside the truck 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Dozier Posted November 4, 2006 Author Report Posted November 4, 2006 Umm. Wheel well to wheel well is like 42 inches and as high as I would like to go up with the box is about 30 inches. The depth from the hatch to rear seats is about 30 inches. I have two XXX 12's and two Us Amps AX3000DE amplifiers. I will run probably rms around 1,500-2,000 daily to both meaning about 3-4,000 total daily. www.AlabamaDrift.com04 Silverado in the works
Dozier Posted November 9, 2006 Author Report Posted November 9, 2006 C'mon...Someone has to know something. It has been six days since I posted on this thread and no answers. www.AlabamaDrift.com04 Silverado in the works
SPLGEO Posted November 9, 2006 Report Posted November 9, 2006 do the crx style or subs foward, port back 6 cubic feet for both will be fine you could tune it lower possibe around 33. use areo ports or a rounded square port, or a rectanmgel port with an 8:1 ratio 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Dozier Posted November 10, 2006 Author Report Posted November 10, 2006 My problem is I do not know what dimensions to build the box. I do not know what size for the port. I want to do a slot rectangular port, but don't know how to get the size I want. Greg at US Amps said to do a 36hz tune and 6 cubes. He gave the good info I needed. But he was unclear on how to build the box. I just need someone to help me get the dimensions I need to build the box and port. Thanks. www.AlabamaDrift.com04 Silverado in the works
AI James Posted November 10, 2006 Report Posted November 10, 2006 Ray is the person to talk to he just hasnt replyed again, my single XXX is in 2.1 and gets about 2300RMS and is loud like that
Ray Posted November 10, 2006 Report Posted November 10, 2006 Il post your box tonight.. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted November 10, 2006 Report Posted November 10, 2006 heres your box..and 25.00 to my paypal.. 42 wide, 18 deep, 19 tall external. the 42x18 panel is 1 1/2 thick..ie: the the woofer mounting. subs up port back port is 16.75x5 wide and 34" long or deep" " tuned to 36.3hz 6.46cuft before 4.279 after. add bracing inside the box also. i accounted for bracing.. should bump, 83.5sqin of port area. have fun 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
