Hey, so i have a 05 civic sedan and i want to put 2 12'' lvl 3 dcs in the trunk. I want to do subs forward port through the rear deck, although I have never built a box with a cylindrical port yet. I was wondering if the shape of the box really matters or I can just get my volume and put a port in. I wanted to do 3cu.ft. net volume. tuned to around 35hz (open to suggestion)
sub info
http://www.dcsoundlab.com/level3.html
Also does it matter how much of the port is outside the box? because it will be poking out a bit to make it through the rear deck.
This is what I came up with, is this a good diameter etc? When I put in a 4'' diameter the length was 6 inches so that didnt seem right.
This wedge will be rotated 90 degrees. The subs will be parallel with how the seats lean back
any advice would be greatly appreciated. I made this thread quick so if i missed anything let me know.
I have a mac so I cant use torres....... :badmood2: I remeasures and need the width to be 35''... if anyone wanted to put that stuff into torres and post a pic here... :peepwall:
So you want to run the aeros external from the box to the rear deck level?
Yes exactly. I want the end of the port flush with the rear deck. Will I count the entire port length for this or just the port inside the box? and is this a legitimate way of having the port.
It's a perfectly legitimate way to run a port but you need to make sure that the box is bolted.
The entire length should be used to calculate the port but the port displacement is only for the part that's inside.
Edited by Joe X
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
