Can someone please help me with a sealed box for 1 SA 10
Go with Ported if you can. I run mine in 1.5cu ft. per sub ported. If you go sealed a one cu.ft. box would be fine.
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
Ok
I've never built a box before so I figure with some help from you guys I could do it. Can anyone please give me the dimensions of the cuts I'd need to make it cux I wanna give my girl a lil setup :)
Enclosure Specifications:
Vb = 0.5 ft^3
External Height = 11 in
External Width = 11 in
External Depth = 13 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 11 x 11
Left & Right Sides = 11 1/2 x 9 1/2
Top & Bottom = 11 x 11 1/2
This is Sundown's recommendation, I don't like it, neither the idea of sealed, as mentioned you should go for a ported enclosure.
Thanks for all the help guys! We'll I was thinking ported tuned to 30hertz but she also doesnt want something super loud cux shes not used to bass. Joe X man you sure do make it ez man :) could you give me the same info on a ported box?
Sure, take a look:
Fb = 35.081 Hz
Vb = 1.24 ft^3
External Height = 12 in
External Width = 24.5 in
External Depth = 14 in
Port Width = 1 3/4 in
Cut List:
Front = 22 x 10 1/2
Back = 24 1/2 x 10 1/2
Left & Right Sides:
Side 1 = 12 1/2 x 10 1/2
Side 2 = 13 1/4 x 10 1/2
Top & Bottom = 24 1/2 x 14
L Port Internal Assembly Parts:
Front to Back = 11 5/8 x 10 1/2
Extension = 13 9/16 x 10 1/2
I chose dims that fit most of the times, best for trunk/hatchback vehicles. Again this is based in Sundown spec Much better than the sealed.
I'd listen to everyone about going ported. Me and my friend just built a box for 2 E8 v2's that was sealed because he has absolutely no room in the back of his F150 and it was all we can fit and he likes the way it sounds but it could be much louder. The box is just too small for the subs, I almost feel bad for them haha good luck with your build!
Heres a pic to show how much this box is we made because of the space issue, I'm honestly not even sure how much cu.ft it is haha first box we've ever built
Edited by ant the ninja
2002 Ford Explorer XLT
Front Stage: Crescendo CCX 6.5's
Rear Stage: ???
Two 15" Powerbass M154
Audiopipe AP15001d
Pioneer DEH-P5100UB
  • Who's Online   1 Member, 0 Anonymous, 1719 Guests (See full list)
