Are my calculations right? 4th order help
doug118
I can't find any solid advice for figuring out a 4th order so I've just taken bits of information from all the threads I've read and came up with this. Box is for 2 sundown sa-12's. This is just for the ported portion. Sealed is 2.05 cubes
Let me know if this will work or if I screwed anything up. I'd like a fairly flat response from around 25-55hz. If I shrink the port height down to 10" and length to 11", it gives me 15.13" port area per cube and tuned to 48hz. Would that be better?
Thanks guys
id bring your sealed side down a little bit. like 1.75 -1.85 area which will require your ported side to be brought down a little as well if you wanna keep the 2:1
other than that it looks good.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
  • Who's Online   0 Members, 0 Anonymous, 1171 Guests (See full list)
