Single or double run of 4/0...?
Got a 320a alt coming in and I currently have a single run of 4/0 welding cable. Would this single run be enough or should I add a second run? I'm using the 4/0 just because I had it already.
Also, as far as fusing from alt to rear bank....opinions?
that one run should be plenty. it doesnt matter what amps you have. if you have enough wire to handle the power supply from the front, you are good. it wont pull current that the car cant supply just because your amps want more.
Cool. The big 3 is all done in 1/0 right now, it'll be changed out to 4/0 when I swap the alt.
As far as grounding goes, should I run another ground from the alt casing/mounting bolt?
What size fuse in the front and rear should I use with the new alt? I currently have 300a at the front and rear
  • Who's Online   0 Members, 0 Anonymous, 1415 Guests (See full list)
