OK, so i have 2 Pionner W309d4 subs. (Dual voice 4ohm 1400 watts and 400 RMS a piece.
And a Hifonics Hifi1000 watt amp.
Subs are wired at 1ohm and YES the amp is capable of an 1 ohm load.
SO the problem is: The protect light on my amp blinks only when the bass hits hard, and it blinks in sync with the bass. :WTFBubble: WTF!!! The sound quality doesn't change at all and even if i crank the volume or gain up it still sounds fine but the protect light blinks even brighter. ALSO, when i crank it up the lights in my cab dim a lil bit. But i dont understand its a Ford F-150, surely its putting out enough volts to power everything.
All of this together really pisses me off.
Problems ive considered: 1. shitty wiring of my subs, 2. shitty wiring of my amp, 3. shitty output of power from battery/alternator.
SO I REALLY NEED SOME ASSITANCE WITH THIS PROBLEM. Thank you :)
"I don't fuck with bitch niggas, partner"
I'll take D Shitty amp settings
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
did you do the big 3?
Please explain this big 3 sir.
There's your problem. There are topics on how to do it. If you do it correctly, just doing the big 3 with that amount of power(~1000rms) could fix your troubles.
97 Suburban
8 custom PSI Platform 3 18's
  • Who's Online   0 Members, 0 Anonymous, 1475 Guests (See full list)
