Box Porn Guru's
OK so no porn here but now that I have your attention I would be ever so grateful if you box gurus would check these numbers before I build. I can't use torres calculator cus I have a gay mac. The following specs were designed on RE Audios box calculator. The sub is an RE Audio XXX 15. For the moment an RE Audio XT4000de version 3 pushing rated 1600 wrms to it. (will be upgrading amps in the future to give the sub the power it wants) Sub displacement is .27 cubes. This is going in a new beetle lol with deleted back seat and will be upfiring. The only spec that is abolute is the box width of 41". I would like to keep the depth( front of car to back of car) at 19 " or less and the height (bottom to top) around the 19" mark or less. I roughly kept it to 15 inches squared per cube for pert area. This is my first box design so be gentle lol. Here Are the specs. I dont know if the RE calculator takes in consideration woofer displacement in the overall volume and tuning? Like i said the sub displacement of thee xxx15 is .27 so with these calculations the box is just slightly over (.156 cubes) than the 4 cubes RE says. So if all you Gurus could help me out, see if the torres says approx the same, see if my tuning and volume are good, and also if the port size is good (hopefully not noisy). 1.5" mdf isn't that cheap lol (might just laminate two pieces of .75) any drawbacks to that???. I only want to build this box once haha.
THANKS.
box width -41''
box height -19''
box top depth -19''
box bottom depth -19''
wood thickness -1.5''
square port height -16''
square port width -4.25''
square port length 1 - 13..25''
square length 2 - 9"
total port length -30.125"
square port diameter -9.3048529833"
square port area - 68"
square port volume internal -2048.5
square port area displaced -2079.625
box volume (feet cubed) -4.426
box volume (inches cubed) -7648.375
tuned freq at 33.4729 hz
2004 VW Beetle turbo'd shiny and able to go boom...DONT ASK ME WHY BUT THE WOMENZ LIKEZ IT.
CURRENT BUILD UNDER WAY
DC AMPS ON PREORDER
STINGER WIRES IN HAND
MECHMAN 270 ON THE WAY
RE XXX 15 IN HAND GETTING REPLACED BY A DC XL M2 SOON
4.1 CUBES @ 33 HZ HITTEN DEM LOWS
XS POWER BATTERIES ON DA WAY
CLARION HU'S LOOKING PURRRDY
FATMAT XTREME AND RATTLE TRAPPED TO THE BALL SACK
THE REST IS A SECRET
anyone? this would be an easy and quick calculation for you pros out there. help a noob and win a prize!!!!
DC AMPS ON PREORDER
no one wans to help a brother out and throw these numbers in the torres for me??? I do not trust the calc on RE Audio's sight. i want to make sure the volume and tuning are right and that the port checks out as well.
DC AMPS ON PREORDER
3.69 cubes net volume (.27 sub displacement figured in)
5.63 gross volume
36.66 tuning frequency
port area 68
port area range 44-59
port volume 1.67 cubes
18.43 port area per foot
why cant you put t in torres and learn the program
not compatable with macs.
DC AMPS ON PREORDER
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
