I just made this box, it sounds like shit. I didnt know about port area before I made it. I wanna make close to the same thing except this time it will have a 3.75" port tuned to about 36 Hz. If I kept the sub firing up and just faced the port back would that be okay? Otherwise I wouldn't have much room for the sub to face forward.
That port looks really small. I would stick with a minimum of 14 square inches of port area per cubic foot.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
I know... I said that in the original post about the port being small and making it bigger
Edited by IKnowImLost224
well port back (at least in my trunk car application) results in a massive amount of trunk rattle which is rather annoying on a large scale.
every application is different, so you'd have to try it for your situation.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Port back sub up on a trunk vehicle is a bad idea. Just doing a wider port neither is going to make a meaningful difference.
i would tune it lower myself. maybe 33.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
WEll I made it wider and kept it in the port area range on Torres until I got the tuning where I wanted. Should I try to do something with both firing back?
Port back sub back can work, high port area (like >= 16 sq in per cube), tune 33-35, extremely solid build is necessary for this sub.
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
