Big 3 with 4awg on stock electrical
im running 1500rms in my car on stock electrical. if i do the big 3 with 4awg wire will i need a 2nd batt? and will the current efficiency improve? (i was going to do the big 3 in 0awg and get a 2nd batt but i figured for 1500rms it would be a waste and not worth it)
2010 Cobalt LT Coupe
Subs: 2 American bass XFL 12s
Amp: Crescendo BC3500D
Big 3 in 1/0awg
29hz box
stinger volt meter
2nd battery Deka 9a31
pioneer DEH-9400BH
just do it in the 0 so you can have it done and not have to pull it off again.
personally i would add a second battery if you can just to make sure your electrical can handle it with some reserve
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
You'd be better off using 0 guage for the big 3 so the current has more area to go through, so your voltage level is more stable.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
but will 4awg without a 2nd batt be okay? if i just do the big 3 with it with nothing else added? i figured it would be better than staying stock and i don't plan on going bigger in my current car so it would be a waste of money buying 2nd batt and 0awg and doing all that
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
105amps. i got a cobalt coupe LT 2010
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
i just don't want anything blowing or my electrical getting messed up if i add 4awg
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
Run 1/0 ga. I have around the same wattage and have over 50 ft in my car. As long as you do it properly the big 3 won't do any damage. All my factory grounds are intact. Its better to do it big the first time. You don't want to have to run more wire after everything is installed. Overdoing electrical is never a waste.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
I run 1500watts with one battery and stock Alt. I use 1/0 wire for power and BIG 3, and have minimal voltage drop. Not only does the Wire matter, but how efficent is your amp? Some amps are WAY more power hungry than others.
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
american bass 100.1 and i've been running this setup on stock for 6months and its been fine. i'd rather just add 4awg since everything works perfectly fine on stock.
Big 3 in 1/0awg
29hz box
stinger volt meter
pioneer DEH-9400BH
  • Who's Online   1 Member, 0 Anonymous, 2103 Guests (See full list)
