Decide what advise you will take and I wil perform the mods, if you listen to rap type of music mainly, I would probably go to 33Hz. A port up / sub front can be done without a problem, it even has the advantage that you can go with an all across width/height baffle without cutting through it. Can you go a bit wider?
I'll do yours joe because then I can try different setups with the same box (fire up, back, up). I can go higher but not deeper sadly, or else it wont be able to fit in the truck through the door :P (Truck is new so I don't want to risk messing it up by building inside the truck. And ya I listen mostly to rap so 33hz would probably be best for me!
realistic max dimensions would be: 34H x 35W x 20.5D
Thanks a lot joe!
2010 F150 FX4
-18" AA Mayhem
-Crescendo BC3500d
-Pioneer GM-D9500F 4-channel
-2 Crescendo FT1
-2 Crescendo Neo Forte 6.5
-Pioneer AVH-P3300BT
-6000K HID Headlights/Fog lights
-All LED interior lighting
-20% tint on front windows, 1% rear windows, 5% windshield strip
-Big3 (XSFlex 0ga)
-DC Power 270XP
-Group 65 NorthStar AGM battery
Coming soon/plans:
-Build log
-Blacked out mirror reflectors
-Tinted tails/3rd brake light
Just wall it and get what you really want
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
Thanks a lot joe!
Ok so updated the design post, 33Hz tuning and within your new dimension limits.
Thanks a lot joe!!! This will bring my Mayhem back to life!
2010 F150 FX4
-18" AA Mayhem
-Crescendo BC3500d
-2 Crescendo FT1
-Big3 (XSFlex 0ga)
-DC Power 270XP
Coming soon/plans:
-Build log
Have fun Hifonics and build it solid with all the bracing shown if possible.
