buckeyes#1 Posted March 13, 2012 Report Posted March 13, 2012 (edited) i seen a post guy was trying to run this off stock alt and battery , could i run this amp at 1 ohm with a 275 amp alternator and a single xs power 3400 battery with big 3 ??? without doing any harm ? oh and a rockford 400,2 amp running my highs Edited March 13, 2012 by buckeyes#1 Quote
HunterJohnson Posted March 13, 2012 Report Posted March 13, 2012 my guess is yes if you have a couple of 1/0 runs to the back Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
buckeyes#1 Posted March 13, 2012 Author Report Posted March 13, 2012 battery is in the trunk so the power runs are short just a long big 3 run .lol Quote
buckeyes#1 Posted March 13, 2012 Author Report Posted March 13, 2012 (edited) Can you? Yes Should you? No im guess thats what im asking i no i can but should i lol . im not in not competitions or hell mayb a hour a day of thumping just didnt wanna do any harm to amp or alt should i run another d3400 2 batteries ? Edited March 13, 2012 by buckeyes#1 Quote
HunterJohnson Posted March 13, 2012 Report Posted March 13, 2012 More batteries is better dude! try it and use a volt meter to see what youre dropping to. If you're dropping to 11 volts time to upgrade Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LoudBimmer Posted March 13, 2012 Report Posted March 13, 2012 It's going to drain your battery very fast. I would defeniatly add another 3400 or you can go with xp3000 Quote
Smoove Posted March 13, 2012 Report Posted March 13, 2012 More batteries is better dude! try it and use a volt meter to see what youre dropping to. If you're dropping to 11 volts time to upgrade I agree try it. add if you need to. Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
mrd6 Posted March 14, 2012 Report Posted March 14, 2012 Agreed ^ if you watch the voltage and dont play it to the point where you are dropping it too low there is no reason you can't run the set up you have described. You will probably not be able to get full power from the amp but if you watch the voltage you will be fine. I was running my 3500 off a 220amp alt and d2700. I would get voltage drop but i just had to watch it and be careful Quote My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
LoudBimmer Posted March 14, 2012 Report Posted March 14, 2012 Do not try it, unless you have extra money for a repair . Quote
