saz 3000d amp with one battery
More batteries is better dude! try it and use a volt meter to see what youre dropping to. If you're dropping to 11 volts time to upgrade
I agree try it. add if you need to.
Agreed ^ if you watch the voltage and dont play it to the point where you are dropping it too low there is no reason you can't run the set up you have described. You will probably not be able to get full power from the amp but if you watch the voltage you will be fine. I was running my 3500 off a 220amp alt and d2700. I would get voltage drop but i just had to watch it and be careful
Team NorthWestSPL
  • Who's Online   2 Members, 0 Anonymous, 1298 Guests (See full list)
