DC Sound Lab
I recently bought a DC 1.2k and was wondering if It was capible of running @ .5ohm without any problems. I've owned the DC PAI 3000.1 (09 amps) and ran it @ .5ohm for like 2 years and it did just fine. Yes I know it might void warrenty but thats not the question at hand. Has anyone done any testing on this?
Ive seen some threads on CA.com where a few claim to have clamped it from anywhere from 1599~1900 @ .5 ohm ... just trying to get some info here.
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Sweet good to know... it expands my coil options muahahaha. Thanks
Always gotta have solid electrical if the amp can handle .5ohm which DC can and it looks like your electrical is up to par. Just keep an eye on the voltage.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
for burps yeah, you could do .5 ohm .
but for daily i would wire higher,
@ .5 ohm daily its not a matter of IF, its when its gonna blow imho...
if u want more power, get a bigger amp :)
Edited by heckvr4
Well its not like I dive around with it on full tilt... Just want to be able to turn it up when I want to. I know the PAI 3000.1's where different boards but I did have it running @ .5 ohm daily up until the day I sold the amp.
IIRC the 1.2k's are rated for up to 16v. Not sure if that makes any difference,
your a derp, i had my 3.5k at .5 daily no problems
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   0 Members, 0 Anonymous, 1228 Guests (See full list)
