Berto Posted March 16, 2012 Report Posted March 16, 2012 A couple weeks ago my car's batteries completly died, I didn't immediatly charge them cuz I was gonna take some of the engine apart to touch some things up. I charged it back up and now all I get is this: And after that screen, no matter what option I choose it sends me to this screen: Then it just goes back to the 1st screen. Is my carputer completly screwed and am I gonna need to reinstall the Windows software again? Or is it something simpler, and cheaper? TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 so what i can tell that is happening, your XP is blue screening, but your monitor isnt quick enough to load windows after the post. basically the part that you left out either because you didnt see it, or you didnt think it matters is this part: windows xp loading screen, then a blue screen (takes about 5 seconds, then you will see the black screen listing your hard drives, etc) 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
n8ball2013 Posted March 16, 2012 Report Posted March 16, 2012 It does that after you hit last known good configuration? it sees your drive. Im wondering if its got a bad cmos battery and it doesnt know its supposed to boot from the drive. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted March 16, 2012 Report Posted March 16, 2012 so what i can tell that is happening, your XP is blue screening, but your monitor isnt quick enough to load windows after the post. basically the part that you left out either because you didnt see it, or you didnt think it matters is this part: windows xp loading screen, then a blue screen (takes about 5 seconds, then you will see the black screen listing your hard drives, etc) Yeah that makes a big difference in whats actually happening. Video time berto. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 so what i can tell that is happening, your XP is blue screening, but your monitor isnt quick enough to load windows after the post. basically the part that you left out either because you didnt see it, or you didnt think it matters is this part: windows xp loading screen, then a blue screen (takes about 5 seconds, then you will see the black screen listing your hard drives, etc) I forgot if the loading screen came up, let me see if I can find my fuse to put it back in and see if it comes up. It's use to go through that black screen extremely fast before, I don't know why it's getting stuck now. TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 basically in this situation you will need your xp cd, boot from the cd and run a check disk. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Berto Posted March 16, 2012 Author Report Posted March 16, 2012 It does that after you hit last known good configuration? it sees your drive. Im wondering if its got a bad cmos battery and it doesnt know its supposed to boot from the drive. Yeah that's the option I tried the most and the same thing kept happening. Let me try to get a fuse to make a vid. EDIT: to add another reply. basically in this situation you will need your xp cd, boot from the cd and run a check disk. I don't have the disk. I bought the carputer used. TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Sheena Posted March 16, 2012 Report Posted March 16, 2012 what OS? xp home edition? pro? 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Sheena Posted March 16, 2012 Report Posted March 16, 2012 and you CAN NOT hit the "Safe mode" option? correct? 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Sheena Posted March 16, 2012 Report Posted March 16, 2012 It does that after you hit last known good configuration? it sees your drive. Im wondering if its got a bad cmos battery and it doesnt know its supposed to boot from the drive. if it was the cmos batt, it would have him press F1 to continue before it went past the POST. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
