I bought 3 dc level 3 12s from my friend and when i got them they read around a 2 ohm loar like they should. I checked the coils today and two of the subs are reading 4 ohms and on the last sub, one coil is reading a 4 ohm load and theother is not reading at all. Is there any reason for this happening?
Are you checking them correctly?
If you wired them in series you would get a 4 ohm load
99 expedition
Two 15 inch dc audio xls
Ported box tunned to 34 hrtz
Soundstream pcx.2000d(better amp soon)
0 gauge
big three(soon)
Yellow top,(more batts soon)
so theyre not hooked up and it happened?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
yeah this is what im thinking...almost has to be your dmm fuckin up... unless a gremlin got ahold of em or something lol
power: dd m4
I missed the fact that you haven't played them in between the readings lol.
Touch the leads on your DMM together. What do they read? And if you look at the voice coil: Is it nice and coppery or is it black, bubbly, and charcoal like?
